Reveb \ Delay with "freeze" feature
Heya,
I have no idea if this one already discussed here, but I see that the last trend in the market is "freeze" button in delays or reverbs vsts. If I understand correctly, what they actually do is to freeze a small piece of a real time played audio and repeat it endlessly when the "freeze" button is pressed, while simultaneously continuing playing the original playback in the background . When the button gets shut off, the freeze effect stops immediately. I guess the method is actually using 2 delays in parallel while the second one is in charge for the "freeze" and it has a fixed "mix" and "feedback" characters set to 100%. When the button is pressed, it freezes a short audio part which is sent to the second delay and get delayed endlessly, until the "freeze" button is shut down. Anyway, I would love to see this feature done in FS so if you guys have any idea how to take it forward, I would love to hear about it.
kortezzzz - Posts: 763
Spogg - Posts: 3324
Re: Reveb \ Delay with "freeze" feature
Thanks spogg! I didn't mentioned it
Hi kortezzzz,
Also check out my "Delay Looper".
viewtopic.php?f=3&t=8197&p=33357&hilit=delay+looper#p33357
Later then and have fun, BobF.....
- BobF
Thank you very much Bob I'll test it up
I'll have to work brill into a sentence. *makes note
Users browsing this forum: Spogg and 68 guests
