Page 2 of 2
Re: Noise Removal
PostPosted: Sun Aug 05, 2018 10:56 am
by Spogg
Well I got the violin file that tulamide linked to (many thanks) and this tool is TOTALLY AWESOME! :o
This is surely a commercial grade processor. Is there anything to compete with it? I’d be surprised, and if there is, it probably costs a small fortune.
I do recall using the noise print method ages ago, possibly in Sound Forge. I don't recall what audio I was working on but It was a lot of messing around and experimentation and the result was full of artefacts. In fact I preferred the noisy version, because our brains can listen “through” the noise somehow. But Martin’s wonderful tool just works!
If I ever need noise reduction this will be my go-to tool.
Once again Martin has shown what a true wizard can do with Flowstone. :ugeek:
I should mention that version 2 needed to have an After Load prim to trigger the RubyEdit. I seem to recall reading somewhere that this was an issue with 3.06, which I’m currently using.
Re: Noise Removal
PostPosted: Sun Aug 05, 2018 11:54 am
by tulamide
Spogg wrote:Is there anything to compete with it? I’d be surprised, and if there is, it probably costs a small fortune.
I wouldn't know. Here's an example, that's still state of the art:
https://youtu.be/826aEnEX8Ak
There is a one knob noise remover, but the results are not as good, and it once cost $60 (but is not available as a single product anymore, the bundle it is included in costs $236):
https://youtu.be/-jtU5pO0HB4
A third one, that is easy to handle, is about $30, but still needs the learning phase (=fingerprint/noiseprint):
https://youtu.be/IoUmKRAi-Ds
Martin's tool is more advanced in terms of usage and results. Yep, this could make some bucks, if Martin opts for it.
Re: Noise Removal
PostPosted: Sun Aug 05, 2018 3:42 pm
by BobF
Hi Martin,
Much needed and Appreciated, great work as always!
Cheers, BobF.....
Re: Noise Removal
PostPosted: Mon Aug 06, 2018 9:04 am
by Spogg
tulamide wrote:... Martin's tool is more advanced in terms of usage and results. Yep, this could make some bucks, if Martin opts for it.
I watched all three videos (thanks for the links tulamide) and Martin’s is the winner!
This could certainly make him some money if he wanted to go down that route.
Re: Noise Removal
PostPosted: Wed Aug 08, 2018 6:42 pm
by tiffy
Thank you, Martin. Tested it and works great.
