Dual Arp Synth
Dual Arp Synth
Postby DSP-Robotron » Tue Aug 18, 2020 3:59 am
This is the old example synth just modified to have an extra arpeggiator that can be de-tuned.
I don't think the second arpeggiator is working properly.
It seems to be doing something but it's not doing it as it's supposed to.
The second Arp seems to receive midi notes but it's not arpeggiating them at all.
Can you guys figure out why the second Arp is not working properly ?
The ON/OFF buttons are not working properly either.
Dual Arp Synth.fsm
Version 0000
(106.02 KiB) Downloaded 96 times
DSP-Robotron
Re: Dual Arp Synth
Postby DSP-Robotron » Tue Aug 18, 2020 3:32 pm
Here is another version that removes the synth part and keeps only 3 Arpeggiators. This one seems to work better but the notes continue to play sometimes even when the led is turned off.
Multi Arp 0001.fsm
(37.26 KiB) Downloaded 86 times
DSP-Robotron
Re: Dual Arp Synth
Postby DSP-Robotron » Tue Aug 18, 2020 10:59 pm
Here is a basic 3x Osc Synth. Now I just need to add a step sequencer/counter/arpeggiator to cycle through the oscillators in order to create wave sequences.
3x OSC Basic Synth.fsm
(59.21 KiB) Downloaded 81 times
DSP-Robotron
Re: Dual Arp Synth
Postby DSP-Robotron » Tue Aug 18, 2020 11:42 pm
Here is a nice basic synth with 3 oscillators where each oscillator is controlled by a different arpeggiator. It's almost doing wave sequencing in a way. Almost.
3x OSC 3x Arp Basic Synth v001.fsm
(105.21 KiB) Downloaded 80 times
DSP-Robotron
Re: Dual Arp Synth
Postby DSP-Robotron » Wed Aug 19, 2020 12:55 am
Here is a formant filter made by Bob but I added the Arp as a modulator to it. It's doing a little modulation but the ranges are probably not matching or need to be remapped or scaled to match properly or something.
StepLFOFormantFilter.fsm
(172.18 KiB) Downloaded 85 times
DSP-Robotron
Users browsing this forum: janicezh1 and 16 guests
