Sample Switching Synth (Using SFZ)
Postby DSP-Robotron » Wed Aug 19, 2020 6:41 am
This thing now works and it's switching samples on each incoming note but there is no way in hell to make all those controls fit into the front panel and is also silently sustaining notes and overloading the CPU. Just watch the CPU load slowly climb to 86% when you activate the Arp. It's supposed to use only 1%. Any ideas how to fix it ?
Wavestate SFZ v002.fsm
(1.03 MiB) Downloaded 97 times
DSP-Robotron
