Phidget sample rate
Phidget sample rate
Hi there
I use the Phidget modules, and it works great. However, it seems that there is no option to set the sampling rate.
As-is it is 50hZ, but the Phidget modules are capable of much higher rates. How can I configure this in FlowStone?
J.
J.
- julik_v
Phidget sample rate
Im using the AC3 passthrough via the A52 Codec which requires the sample rate to match on the movie and audio output interface for it to work. My videos all use a sample rate of 48KHz, so I set this in Audio MIDI Setup for my digital out. However, every time I restart the setting is lost and is set to 44KHz. Does anyone know how to make it stick at 48KHz?
- Bowkew
