X10 Home Automation PIR Test
A wide range of example files that you can load up in FlowStone
Postby admin » Tue Sep 21, 2010 5:01 pm
In this example FlowStone sends out the X10 commands to the Marmitek CM15 Pro USB X10 Controller to turn a simple lamp on and off from a wireless Passive Infrared sensor (PIR) (Marmitek MS13E Motion Detector).
The PIR address is set to A1 and the lamp address is set to A2
Any movement detected by the PIR switches the lamp on for 10 seconds!
X10 PIR Test.fsm
X10 PIR Test
(12.56 KiB) Downloaded 4914 times
admin
Site Admin
Return to FlowStone Examples
