Audio Gain and EQ
Audio Gain and EQ
Postby admin » Mon Jul 12, 2010 4:08 pm
This example uses a Voltage Controlled Amplifier (VCA) to control the volume of the audio signal coming from the Sound Card and a State Variable Filter to change the EQ settings.
Try playing some sound into your soundcard and listen to the results as you move the knobs.
Audio Gain and EQ.fsm
VCA and State Variable Filter
(30.01 KiB) Downloaded 3294 times
admin
Site Admin
Return to FlowStone Examples
