Auto Correlation
Auto Correlation
Postby admin » Mon Jul 12, 2010 4:46 pm
This example shows how to use the Auto Correlation Module to correlate a signal with itself or two separate real-time signals.
In this case a sine wave input is used and correlated with itself, the slider controls the delay factor for the Correlation
The real-time Correlation factor is output as well as the average correlation factor.
Basically the output is highest when the two signals match or are in phase.
Auto Correlation.fsm
Auto Correlation
(26.78 KiB) Downloaded 2856 times
admin
Site Admin
Return to FlowStone Examples
