FM Modulator + De-Modualor
Postby admin » Fri Jul 16, 2010 5:56 pm
In this example an FM (Frequency Modulation) modulator and de-modulator are made to transmit audio along a transmission line.
When you speak into the soundcard mic input the sound is modulated into a carrier frequency, then de-modulated and fed through a LPF (Low Pass Filter) to re-create the original.
You could use this method to transmit an audio signal along a single twisted pair of wires over a long distance with out any interference.
This is also useful to show students how a radio works!
FM Modulator De-Modulator.fsm
(22.86 KiB) Downloaded 3004 times
admin
Site Admin
Return to FlowStone Examples
