Selector Example
Selector Example
Postby admin » Wed Aug 25, 2010 10:25 pm
This example shows how to use the selector module.
First to make the equivalent of:
If x = 1 then y = 2
Else
If x = 2 then y = 5
Etc..
In this part the input integer (eg. x) controlled by a slider select one of 10 possible outputs.
In the second part we use the Selector to select from two different audio oscillators:
0 = No Sound
1 = OSC 1
2 = OSC 2
3= OSC 1+2
Remember the ‘select’ module works for almost all data types, Floats, Integers, Bools, Audio, graphics etc.
Selector.fsm
Selector Module
(32 KiB) Downloaded 2744 times
admin
Site Admin
Return to FlowStone Examples
