comparing elements in array
I'm looking for an efficent solution for finding a single "peak" value within a small array (less than 50 elements). While I could do this with greens - at 25fps and some other stuff going on - I think ruby may be faster on that. Here it is what I exactly look for.
Let say that I have an array of floats, like this:
121
90
77
66
51
30
37
43
51
43
36
22
10
In above example - the peak is at index 8.
Concept:
- peak is a value at index N, greater than values at N-1 and N+1 indexes
- there will be only a one single peak in such array
- border values (lowest and highest) are never a peak values
- peak value does not have to be "max" in array (otherwise - it would be simple)
- it has to be efficient calculation (25fps or more), thus parsing the whole array per each comparison should not be done by greens, rather ruby.
121
90
77
66
51
30
37
43
51
43
36
22
10
Concept:
Re: comparing elements in array
It is called local maximum. No ruby needed...
local maximum.fsm- (878 Bytes) Downloaded 848 times
Thanks, I did not knew that it's possible that way.
