path splitter/maker
path splitter/maker
I think I remember, someone asked about such tool some time ago.
Path splitter/maker for component management. It takes source path (for example from loading file dialog box) and creates a folder with sufixed files. Can be used to provide destination path, next to the source file when saving output. File extension can be provided externally.
path-splitter.fsm- (700 Bytes) Downloaded 752 times
Re: path splitter/maker
I just noticed weird thing. When exporting wave files in this way - FS seems to create folder, but no wave file. It exports wave after folder is created, so I guess there is some internal problem with order.
So here is a quick fix. Trigger creates the folder on first place, and the process is started. Tested, works.
path-splitter-001.fsm- (780 Bytes) Downloaded 728 times
