Looking for a bandpass filter design with bandwidth control.
Postby zoobooboozoo » Wed Oct 08, 2014 9:29 pm
Hi all.
I'm looking for a bandpass filter design with frequency & bandwidth controls/inputs.
Ruby/DSP are preferable. a general design or green will also do :)
zoobooboozoo
Re: Looking for a bandpass filter design with bandwidth cont
Postby martinvicanek » Thu Oct 09, 2014 7:42 am
Search for RBJ biquads.
Postby zoobooboozoo » Thu Oct 09, 2014 9:57 am
I found this:
http://flowstone.guru/downloads/rbj-biquad-filters/
But the bandpasses doesn't have a BW control. Am I missing something?
zoobooboozoo
Postby martinvicanek » Thu Oct 09, 2014 10:06 pm
You're almost there!
Bandwidth = Center_Frequency/Q
Note:
Center_Frequency is sometimes labeled "Cutoff Frequency".
Q is sometimes labeled "Resonance".
Postby tulamide » Thu Oct 09, 2014 10:28 pm
martinvicanek wrote:You're almost there!
Note:
Thank you for this info! While it may seem easy, I always wondered about it. That helps a lot to get in touch with the very abstract filter language/design/math, etc.
If there are more such tips, that make it easier to understand the relations of all the parameters, please share them :)
Postby zoobooboozoo » Sat Oct 11, 2014 12:53 pm
Thx martin!
Now I have a different problem. I want to control the cutoff with numinal frequency in hz(like 270, 440 1850 etc...) but I can't seem to make the proper conversions so that the float frequency provides the RBJ Biquad with what it needs...
zoobooboozoo
Postby KG_is_back » Sat Oct 11, 2014 1:40 pm
There is a stock module called "hz to 0-1" or something like that. Basically you have to divide the frequency in Hz with half the samplerate.
KG_is_back
Postby zoobooboozoo » Sat Oct 11, 2014 2:43 pm
Yeah for some reason I cannot connect the "hz to 0-1" module to either directly the cutoff input or the "scale cutoff" module...
zoobooboozoo
Postby zoobooboozoo » Mon Oct 13, 2014 9:44 pm
Could anyone help?
I'm really trinyg different methods but can't get to where I input into a bandpass filter:
1)frequency somewhere between ~200-5000
2)Q/res based on the above frequency and bandwidth value of ~50-140
For some reason the values gets lost in translation with both the stock bandpass filter and the RBJ biquads...
zoobooboozoo
Postby martinvicanek » Tue Oct 14, 2014 1:38 am
Here you go. (That's a very narrow bandpass filter.)
Bandpass.fsm
(121.28 KiB) Downloaded 991 times
