Preset manager There you use folder
Postby djbrynte » Wed Sep 16, 2020 4:17 pm
Hi every one i wonder if some one could help me make a preset manager There you put the preset banks in a folder beside vst There you can select preset bank in a list box or something. Lets say u put New banks inside this Map then they should show up in that list.
djbrynte
Re: Preset manager There you use folder
Postby MichaelBenjamin » Wed Sep 16, 2020 6:54 pm
Last edited by MichaelBenjamin on Mon Sep 21, 2020 11:02 am, edited 1 time in total.
MichaelBenjamin
Postby RJHollins » Thu Sep 17, 2020 1:44 am
Something I had to do with a project awhile back ...
Something called the 'Marshall' format [i think that's what it was called].
TROG is the one that pointed me how to do this ... with RUBY.
I've long forgotten the details ... but it might show up in a search .... or was that back in the SM daze ... :|
Postby kortezzzz » Thu Sep 17, 2020 5:36 am
Here are 2 examples using 2 different methods for fast saved preset banks switching. Bare in mind that you'll have to locate the target preset bank folder first to make it work properly. The first method is radio buttons menu based on Trog's Ruby selector (including scrolling feature). Once you save a bank, it will instantly appear in the menu. Saving any additional bank will switch to that new bank after saving. Same operation method is applied to the second example, which is simple drop list menu.
(PRESET BANK MAKING EXAMPLE).fsm
(231.55 KiB) Downloaded 1108 times
kortezzzz
Postby kortezzzz » Thu Sep 17, 2020 5:37 am
(PRESET BANK MAKING EXAMPLE 2 WITH DROPLIST).fsm
(224.04 KiB) Downloaded 1181 times
kortezzzz
Postby djbrynte » Thu Sep 17, 2020 9:09 am
Will check this out soon kortezzz
djbrynte
Postby djbrynte » Thu Sep 17, 2020 9:15 am
thanx alot kortezzz exactually what i was looking for.
djbrynte
