What the ..... Now my Flowstone start to CRASH
Postby frankriedel » Mon Sep 10, 2012 4:30 am
And i can't get it to run again.....
Tryed to remove everything of the program also in REG database - reinstall the Flowstone program...
but it still crash right after boot !
Any HELP ?????????????????????????
frankriedel
Re: What the ..... Now my Flowstone start to CRASH
Postby frank-riedel » Mon Sep 10, 2012 9:10 am
Yeahhh - got it back up and running by removing every KEY in Reg.DB. and installed Ver. 1.01 first and then update to Ver. 2
Hope this will work for others
Frank
frank-riedel
Postby support » Mon Sep 10, 2012 2:08 pm
Good to hear you got it working Frank. Btw. it looks like you have two accounts on the forum, was that intentional? Please contact us if you want to remove one of them.
Here are some expanded instructions on how to reset FlowStone settings for anyone else who encounters this:
  1. First make sure you kill any instances of FlowStone you see in the task manager
  2. Click the Windows Start button, type RegEdit in the search box and press return (click Yes on the security dialog)
  3. Navigate to HKEY_CURRENT_USER\Software\DSPRobotics
  4. Expand this node to reveal the FlowStone node underneath
  5. Right-click on FlowStone and select Delete. You will be asked to confirm this.
  6. Now close RegEdit and run FlowStone again
Note that this will reset your FlowStone preferences back to defaults.
support
Postby frank-riedel » Fri Sep 21, 2012 6:48 am
Thanks...
I do not intend to have 2 account... I will continue this one... Please delete the other
Regards
Frank
frank-riedel
