Ruby.Array.Problem.(Solved)
Postby Parki » Sun Mar 08, 2015 10:58 am
Look to the file.
Ruby.Array.Problem..fsm
(1.22 KiB) Downloaded 827 times
I hope my english was understeandable.
Skype id - parkidesu
Parki
Re: Ruby.Array.Problem.
Postby Nubeat7 » Sun Mar 08, 2015 11:31 am
Postby Parki » Sun Mar 08, 2015 1:46 pm
I won't be rude but...
Any work code which add an array to array?
Parki
Postby Nubeat7 » Sun Mar 08, 2015 10:33 pm
you can find all you can do with arrays in the link above
http://ruby-doc.org/core-2.2.0/Array.html#method-i-2B
to add an array to another just "add" them,
so if you want to add arrayB to arrayA:
arrayA = arrayA + arrayB
or shorter
arrayA += arrayB
Postby tulamide » Tue Mar 10, 2015 1:35 am
Nubeat7 wrote:http://ruby-doc.org/core-2.2.0/Array.html#method-i-2B
I propose to link to core 1.9.3 instead, because that's what Flowstone uses. It has no influence on this particular question, since nothing has changed for arrays. But this might not always be the case. :)
Postby Parki » Tue Mar 10, 2015 12:13 pm
I almost pray for it would be last.
5.fsm
(1.19 KiB) Downloaded 809 times
Parki
Postby TheOm » Tue Mar 10, 2015 12:47 pm
Take a look at this:
5.fsm
(1.3 KiB) Downloaded 821 times
TheOm
Postby Parki » Tue Mar 10, 2015 2:46 pm
Thank you guys for your help me with my idiotic problems with syntax.
Parki
