Why can't I output 2 MIDI?
Postby Nowhk » Tue Apr 28, 2015 10:22 am
I'm trying to do a sort of MIDI filtering in Flowstone.
Once a switch is clicked, MIDI pass onto a MIDI pin (data that I'll use, linked to another plugin), else on another (a dead endpoint, which nothing will happen).
This is the basic schema:
but once I export it as VST, and I load it on FL Studio Patcher, I can just see 1 output pin. Where am I wrong?
i.e. How can I ignore MIDI once Switch is on?
MIDI Port Switcher_2.fsm
(136.15 KiB) Downloaded 690 times
Nowhk
Re: Why can't I output 2 MIDI?
Postby nix » Tue Apr 28, 2015 10:53 am
Generally in a plugin you can't have two MIDI outs.
There are 16 channels in one output though.
Hope helps Nowhk
Here is one way to do this->
nix
Postby Nowhk » Tue Apr 28, 2015 2:44 pm
I see. Thank you ;)
Nowhk
