Setup priority on MIDI Execution - Delay?
• Page 2 of 2 • 1, 2
Re: Setup priority on MIDI Execution - Delay?
It's fine to delay triggers-
even MIDI(with Ruby) I imagine.
It's not necessary here though, the link order thing should be fine IMO
If the changes are too fast, and it doesn't work right,
you can introduce a 'timer' if needed, on the trigger
Nice idea
Nice idea
maybe the R&D primitive: Midi Buffer
could help here...
Flush the second buffer after a short delay?!
could help here...
You may use Ruby, to order midi messages in specific order, if they arrive at the same time.
For example this code will accumulate all note on and note off messages that arrive at the same time and order them properly, that all note on preceed note off. Other messages (like CC) are simply passed as they are
input midiIn, output midiOut
def init
@noteon=[]
@noteof=[]
def event i,v,t
if i==0 #ariving messages
midi=@in.to_array
if midi[0]==144
@noteon << midi
input 99,nil #schedule buffers emptying after all notes are received
elsif midi[0]=128
@noteof<< midi
else
output @in
elsif i==99 #clear buffer
@noteon.each{|note|
output Midi.new(note[0],note[1],note[2],note[3])}
@noteof.each{|note|
@noteon=[]
@noteof=[]
