Wireless Issues
Wireless Issues
What would cause a working Wireless Connection to stop working?
I have tried unconnecting it, reconnecting it, deleting it, redoing it - still will not work now
What is the PROPER Method to use a wireless connector?
Thanks,
Aron
Thanks,
Aron
aronb - Posts: 154
Re: Wireless Issues
UPDATE:
Ok, I made sure to make each connector type the same (Stream), and it works... So I am guessing you need to make each connector type the same, and not have Flowstone choose the connector type - which is different than regular connectors - does this sound correct?
Thanks,
Aron
Thanks,
Aron
aronb - Posts: 154
Re: Wireless Issues
Yes, you've got it - the name and the connector type both have to match. I've made it a habit to select the connector type for a wireless connector before I even link it to anything - that way, I know that FlowStone won't mess up the connection by changing the type when I'm editing or loading a saved schematic.
Re: Wireless Issues
Yay!
Thanks Trog...
I don't use them often, but now I may do a bit more wireless stuff (I get too many wires at times)
, and now I finally have a proper use case
Continually learning!
Aron
Thanks Trog...
Aron
aronb - Posts: 154
Users browsing this forum: Google [Bot] and 4 guests
