FM modulation unwanted artifacts
Postby Father » Sat Dec 12, 2015 6:34 am
How would you eliminate the noisy artifacts when doing a simple FM setup like the example?
Is this the right way to do it at all?
FM noise.fsm
(30.72 KiB) Downloaded 860 times
Father
Re: FM modulation unwanted artifacts
Postby Spogg » Sat Dec 12, 2015 11:37 am
Hi Father
I believe the noise is caused by wavetable switching inside the Prim. If you set the FM knob to a low value the noise goes. A set of wavetables is created by the Prim to limit bandwidth based on the base frequency selected for the note played. With a wide FM excursion in the Freq input the Prim will be selecting different tables rapidly.
The more usual approach is to modulate the phase. This means altering the readout rate from a single chosen table and the sound is the same but without wavetable switching.
I've Spogged your schematic: Changed the FM input to the Phase input and changed the FM knob to go between 0 and 1 and to my old Vulcan ears the result is good.
If I'm wrong about all this I'm sure someone will let us know!
FM noise spogged.fsm
(110.88 KiB) Downloaded 849 times
Postby Father » Sat Dec 12, 2015 4:28 pm
Aha didn't know that.
Yes sounds good enough i think, and its very similar to the old one which is good.
Thanks so much :)
Father
Postby Father » Sat Dec 12, 2015 8:19 pm
Still happening, specially with different waveforms its more obvious and annoying.
Does this happen only with wavetables?
Father
Postby martinvicanek » Sat Dec 12, 2015 10:00 pm
Postby Father » Sat Dec 12, 2015 11:47 pm
martinvicanek wrote:It's a bug;
Oh man that's too bad. :|
Father
Postby martinvicanek » Sun Dec 13, 2015 12:03 am
Not necessarily:
1. You can use algorithmic oscs that allow through zero FM
2. Now with the new 3.0.9 features we can build our own wave reader ;)
Postby Father » Thu Dec 17, 2015 1:11 am
martinvicanek wrote:Not necessarily:
1. Not following you, a quick example would be great if you have the time.
2. Thats nice. Well have to upgrade for that.
Father
Postby martinvicanek » Thu Dec 17, 2015 7:55 am
Father wrote:1. Not following you, a quick example would be great if you have the time.
Scroll down...
Father wrote:2. Thats nice. Well have to upgrade for that.
Not sure it is stable yet. :(
WaveTableRead-primitive_bug2.fsm
(20.14 KiB) Downloaded 855 times
Postby Father » Thu Dec 17, 2015 4:06 pm
Nice stuff. the polyBLEP Saw Osc sounds clean! (I think hehe). I just wish it was a wave table read :lol:
Any chance the bug gets fixed on next update?
Father
