Sorting File paths
Sorting File paths
Postby adamszabo » Wed Oct 05, 2016 12:36 am
Hey guys, i've been scratching my head over this one. Lets say I have an array containing some file paths:
Folder/1.txt
Folder/23.txt
Folder/6.txt
Folder/Piano.txt
Folder/Wave01.txt
Folder/Wave02.txt
Zebra/1.txt
Zebra/76.txt
Zebra/9.txt
Now when ruby gets these paths it looks different from windows. Ruby thinks 23 comes after 1 because it starts with a 2, but they should be numerically higher, like this:
Folder/1.txt
Folder/6.txt
Folder/23.txt
Folder/Piano.txt
Folder/Wave01.txt
Folder/Wave02.txt
Zebra/1.txt
Zebra/9.txt
Zebra/76.txt
Is there a way to sory them by using the .sort_by function or something else?
Thank you!
adamszabo
Re: Sorting File paths
Postby tulamide » Wed Oct 05, 2016 9:30 am
What you are looking for is called "natural sort". I found a conversation on StackOverflow here, and made a quick fsm. It isn't bullet-proof! If any of your strings start with a number it will result in an error. However, if your strings are like in your example, it works.
To make this work in your project, you have to make sure that this code is initialized before you access it:
class String
  def naturalized
    scan(/[^\d]+|[\d]+/).collect { |w| w.match(/\d+/) ? w.to_i : w }
natural_sort_2.fsm
(434 Bytes) Downloaded 853 times
Postby adamszabo » Wed Oct 05, 2016 12:18 pm
Ah thank you, just what I was looking for! :mrgreen:
adamszabo
