MIDI to string conversion?
SynthMaker always had a feature that if you connect a MIDI output to a string input it would convert the MIDI message into a human readable string.
It still is there in FlowStone but the resulting string is a ghost... if you read it's length it says zero and if you connect it to another string it does not transfer. Seems only cutting and pasting can make the ghost string real.
Is this a bug or feature (and if the latter, why)?
Is there a workaround so I can use the MIDI to text translation implicit in this function to show midi messages in something like a MIDI-monitor application?
(I know I could replicate the MIDI-to-text functionality but that would be silly since Jorge did that work 15 years ago!)
- oddson
Re: MIDI to string conversion?
It's very strange. It seems the midi->string connection is not really working as it should. For example if you connect a second string prim to the first one, neither of them show the string. What I think it's happening, midi-string connection serves merely as a debug - the string shown is not really there.
There are several workarounds. The best one is to use Ruby. Ruby can convert incoming midi into ruby array of values, which then can be manipulated into human-readable form. For details see manual page 221.
MIDI splitter converts to values as well and I don't have to learn Ruby to use it.
Seems silly if the text is right there but I can't get at it.
I was thinking of pointing potential users here as MIDI troubleshooting and manipulation were early strengths of SynthMaker... now it seems just a shell for Ruby users.
Maybe it could be reported and fixed
nevermind
- oddson
