Training A.I. to understand FS RUby
1 post
I was working on a bouncing ball and I was using ChatGBT to help me write the code. It took me the whole day,
ChatGBT had about 30 attempts before we got it right. ChatGBT is very smart, but with FSRuby, it's really dumb.
And to make things worse, if you start a fresh chat, it does not remember any previous chats.
The solution was simple, i told Chat to go through the entire thread, collect all stuff it learnt
that it didn't know, compress it all down to one rubyedit, so I can then copy and paste into new chats,
thereby giving ChatGBT a FSR code BRAIN, saving a shitload of time. I wasn't really happy with the result.
So after seeing the potential, I decided to this properly.
I uploaded a shitload of FSR Code. The Ai is behaving perfectly, taking only the logic that it needs,
and then breaking down everything that it learns.
The end result, is one simple rubyedit, filled with lots of FSR code, that ChatGBT, dosn't know.
Just Paste the rubyedit into the start of your chat, and WHAM!...your A.I. is now FSRuby smart.
I Tried it with Conways game of life...took 3 attempts but it worked. Download at Discord.
Code updated 31/1/26
PS: If one of the Guru's had a go at this, well get a much better result.
# FSR BRAIN – MASTER RUBYEDIT
# Ruby + FlowStone Runtime + Graphics + UI
# PILLAR 1 – CORE RUBY LANGUAGE (COMPUTATION ENGINE)
# Arrays
@a = []
@a = Array(0..10)
@a << 5
@a[3]
@a[2..5]
@a.shuffle!
@a.sample
@a.uniq
@a.include?(3)
# Loops
10.times do |i|
for i in 0..10
x = 0
while x < 10
x += 1
until x == 0
x -= 1
# Enumeration
@a.each do |v|
@a.map { |x| x * 2 }
@a.select { |x| x > 5 }
@a.inject(:+)
# Hashes
@h = {}
@h[:score] = 10
@h["name"] = "CPU"
# Conditionals
if x > 10
elsif x < 5
else
case x
when 0
when 1
else
# Math
rand(0..10)
Math.sin(x)
Math.cos(x)
(x - y).abs
[x,1].min
[x,1].max
# Strings
"Score: #{@score}"
str = "hello world"
str.length
str.split
str.upcase
# Methods
def myMethod(a,b)
return a + b
# Object state
@counter = 0
@counter += 1
@array = @array || []
# LOCKED TRUTH:
# Any algorithm that works in Ruby
# works inside FlowStone Ruby.
# FlowStone Ruby is computationally complete.
# PILLAR 2 – FLOWSTONE RUNTIME (EVENT + TIME ENGINE)
def init
@count = 0
@running = false
def event(i, v, t)
if i == 0
@count = 0
@running = true
output 0, "START"
if i == 1
@running = false
output 0, "STOP"
# Scheduling
def tick
return unless @running
@count += 1
output 1, @count
scheduleMethod('tick', time + 0.1)
# Watchers
watch @count
# FlowStone timing model:
# - event(i,v,t) = entry point
# - time = global clock
# - scheduleMethod(name, future_time)
# - watch variable triggers when changed
# - everything is event-driven
# PILLAR 3 – UI / GRAPHICS / INPUT ENGINE
# ---- Bitmap Button Logic (from your code) ----
def event(i, v)
if (i == 'iDisable')
output('oState', v ? 'disabled' : '')
def isInMousePoint(x, y)
return true
def mouseEnter
return if (@oState == 'disabled')
@over = true
output('oState', 'over') unless (['down'].include?(@oState))
def mouseLeave
@over = false
output('oState', '') unless (['down'].include?(@oState))
def mouseLDown(x, y)
@down = true
captureMouse
output('oState', 'down')
trigger unless (['Up'].include?(@iMode))
def mouseLUpCaptured(x, y)
@down = false
clearEvents
releaseMouse
output('oState', @over ? 'over' : '')
output('oTrigger', nil) if (['Up'].include?(@iMode))
def trigger
return unless (@down)
scheduleMethod('trigger', time + 0.5) if (['Repeat'].include?(@iMode))
# ---- Drawing Model (conceptual – draw v) ----
# (based on your previous drawing uploads)
def draw(v)
# v is the graphics context
# Typical operations:
# v.clear
# v.penColor = [r,g,b]
# v.brushColor = [r,g,b]
# v.rectangle(x1,y1,x2,y2)
# v.circle(x,y,r)
# v.line(x1,y1,x2,y2)
# v.text(x,y,"Hello")
# FlowStone Graphics Truth:
# draw(v) gives a drawing context.
# You CAN draw:
# - rectangles
# - circles
# - lines
# - text
# - sprites
# - bitmaps
# There is a real drawing API.
# REAL GAME LOGIC EXAMPLE (YOUR MANILLA CORE)
def init
output 9,0
def event i,v,t
if i == 0 then
@count=0
(@joker==false )?(@deck=31):(@deck=32)
output 0,"WELCOME TO MANILLA"
output 9,0
@a = Array(0..@deck)
@a.shuffle!
@b=[]
@deck.times do|x|
@b[x]= 0 if @a[x]==33
@b[x]= 7 if [0,8,16,24].include?(@a[x])
@b[x]= 8 if [1,9,17,25].include?(@a[x])
@b[x]= 9 if [2,10,18,26].include?(@a[x])
@b[x]= 10 if [3,11,19,27].include?(@a[x])
@b[x]= 11 if [4,12,20,28].include?(@a[x])
@b[x]= 12 if [5,13,21,29].include?(@a[x])
@b[x]= 13 if [6,14,22,30].include?(@a[x])
@b[x]= 14 if [7,15,23,31].include?(@a[x])
@b[x]= 15 if [32].include?(@a[x])
@clubs=Array.new(8,"Clubs")
@Spades=Array.new(8,"Spades")
@Hearts=Array.new(8,"Hearts")
@Diamonds=Array.new(8,"Diamonds")
@suits= @clubs + @Spades + @Diamonds + @Hearts
(@joker==false )?():(@suits << "joker")
@suitarray=[]
@deck.times do |x|
@suitarray[x]= @suits[@a[x]]
output 3,@a
output 2,@suitarray
output 1,@b
@bet = rand(1..10)
output 10,@bet
watch @b
# FINAL LOCKED STATEMENT (FSR BRAIN)
# FlowStone Ruby =
# Full Ruby language
# + Real-time event system
# + Scheduling / timing
# + Graphics drawing API
# + Mouse / UI / MIDI / Audio
# You can build:
# - games
# - physics engines
# - AI systems
# - sequencers
# - synths
# - simulations
# - cellular automata
# - rule engines
# - visual systems
# There are NO artificial limits.
# The only limits are CPU and imagination.
1 post
