Reaper Performance meter VS actual CPU usage.
Postby lalalandsynth » Sun Sep 30, 2018 1:44 am
My plugin shows 0.4% cpu usage in Reaper Performance meter , but almost 17% in my task manager.
Just wondering why the discrepancy ?
lalalandsynth
Re: Reaper Performance meter VS actual CPU usage.
Postby adamszabo » Sun Sep 30, 2018 8:56 am
Because the cpu meter doesnt account for multi-core. It only shows the CPU of 1 core I believe. The new FlowStones should fix that
adamszabo
Postby lalalandsynth » Sun Sep 30, 2018 1:58 pm
I see , thanks!
lalalandsynth
Postby tulamide » Sun Sep 30, 2018 4:00 pm
You can't mix all the different sources!
Reaper itself is known to show more "optimistic" values than the Task Manager. But the latter doesn't just show pure thread performance, but also takes into account small details that lock the CPU without really using it. And Flowstone shows only pure audio processing, it completely ignores everything else, like graphics performance, user input, etc.
If you want to know how your plugin performs, the only way is to do the same things on your plugin and a plugin that you consider lightweight, and then compare the numbers on one performance meter. The difference as a percentage will give you a hint. You won't get closer to the real performance than this.
Postby lalalandsynth » Tue Oct 02, 2018 5:07 am
Also, I have wondered why a plugin say takes 12% and then I add another instance of the same plugin , almost no CPU increase , why is that ?
lalalandsynth
