Random number generator
Postby TeslaTronik » Sun Mar 24, 2019 6:57 pm
Im using Rand Module to make a Random number generator, i assumed the seed option would allow for the input of a seed then a sequence of random number based of that seed, bbut it does not work how i expect. to clarify i want to input a value or string as a seed and based of that seed the random numbers should always have the same sequence.
I.E-- Seed = egg : result = 1,,5,33,7,,5,6,3,4...ect.. so egg should always produce this sequence.
Any idea how i can get this behaviour?
Thanks.
TeslaTronik
Re: Random number generator
Postby tulamide » Mon Mar 25, 2019 3:13 am
Hmm, I'm not sure where your issues come from, but the rand prim does exactly that!
I don't have access to FS3 right now, but if you recreate the screenshot (I've set up 2 seeds, you can freely choose to always use the same, or alternate as you see fit), it should work.
Postby BobF » Mon Mar 25, 2019 8:47 pm
Hello TeslaTronik,
Try these and see how they work for you!
BobsRandNumberGenerators.fsm
(186.3 KiB) Downloaded 842 times
Later then, BobF.....
BobF
Postby TeslaTronik » Mon Mar 25, 2019 10:39 pm
@ tulamide, Yes you are correct, it was the method of how i hooked it up which was wrong. thank you.
@Bobf thanks i will take a look at these :),, i love the idea of randomly generated parameters and sounds.. so the more methods the better.
TeslaTronik
