BUG - You found a bug? Post here.
Bug Green:
Primitive:
Float - always reset to 0 when dragged.
Less Then or Equal - It has the function inverted whit normal Less Then
Primitive:
- Tronic
Re: BUG - You found a bug? Post here.
Found a bug. . .
Whenever you have bitmaps loaded via Ruby (Stock Bitmap module) & in one of your Ruby module's you run into excessive processing, it shuts off ALL Ruby modules. So you save the schm to check this out further .
When you load it, all the "bitmap Rubies" are off. Switch em on again & they have errors. . . Nil.
You have to load the bitmap again into it for it to work correctly.
Maybe it was because I saved it while the modules were off but it shouldnt clear the bitmap file "cache" too . . .
- Drnkhobo
Re: BUG - Huge use amount memory when navigate in toolbox
Huge use amount of ram when navigate with the toolbox tab,
the memory does not seem to be released, but always added, even after a long period of inactivity.
- Tronic
