Reveb \ Delay with "freeze" feature
Postby kortezzzz » Wed Jul 31, 2019 11:12 am
Heya,
I have no idea if this one already discussed here, but I see that the last trend in the market is "freeze" button in delays or reverbs vsts. If I understand correctly, what they actually do is to freeze a small piece of a real time played audio and repeat it endlessly when the "freeze" button is pressed, while simultaneously continuing playing the original playback in the background . When the button gets shut off, the freeze effect stops immediately. I guess the method is actually using 2 delays in parallel while the second one is in charge for the "freeze" and it has a fixed "mix" and "feedback" characters set to 100%. When the button is pressed, it freezes a short audio part which is sent to the second delay and get delayed endlessly, until the "freeze" button is shut down. Anyway, I would love to see this feature done in FS so if you guys have any idea how to take it forward, I would love to hear about it.
kortezzzz
Re: Reveb \ Delay with "freeze" feature
Postby kortezzzz » Wed Jul 31, 2019 11:24 am
kortezzzz
Postby Spogg » Wed Jul 31, 2019 12:47 pm
Martin recently did this and it's brill!
viewtopic.php?f=3&t=18218#p55242
Postby kortezzzz » Wed Jul 31, 2019 1:24 pm
Thanks spogg! I didn't mentioned it :D
kortezzzz
Postby BobF » Thu Aug 01, 2019 2:39 am
Hi kortezzzz,
Also check out my "Delay Looper".
viewtopic.php?f=3&t=8197&p=33357&hilit=delay+looper#p33357
Later then and have fun, BobF.....
BobF
Postby kortezzzz » Thu Aug 01, 2019 12:49 pm
Thank you very much Bob :D I'll test it up
kortezzzz
Postby wlangfor@uoguelph.ca » Sat Aug 24, 2019 6:25 pm
Spogg wrote:Martin recently did this and it's brill!
I'll have to work brill into a sentence. *makes note
My youtube channel: DSPplug
Users browsing this forum: No registered users and 53 guests
