The problem with the memory.
Postby borodadada » Sat Jul 20, 2013 10:35 am
1 Create a plug-in it a large number of input and output stream, if I connect all outputs to the output stream audio in the FL Studio, the amount of memory occupied by the plug-in is measured in gigabytes. As soon as I disconnect all the cables from the audio outputs, then plug again, consumes little memory, a few megabytes.
2 If i run this plug-in FL once, and close flowstone , and open again, flowstone not started, will swear the lack of memory.
1 i use delay in write on DSP , methode use Array, 1 array 2 800 000 byte, kill memory methode.
borodadada
