what's new in Snowflake...
• Page 2 of 2 • 1, 2
Re: what's new in Snowflake...
Had another look at the tags issue. There is an issue in the install - it's overwriting the tag files. This would affect you if you've changed the tag bar or you've reassigned tags for primitives. Module tags should not be affected.
Sorry about this. We'll correct the install so it only writes if the tag files don't exist.
support - Posts: 151
only Tagbar.TXT in AppData\Flowstone\Tags was overwritten with default i think:
Inside this folder are the user tags with their names..
I just edited the Tagbar.TXT and added my user tags like Luddite(w/o .tag) again...
External
Element
Maths
String
Flow
DSP
Audio
Imagery
GUI
System
Debug
Thanks Walter. That's been corrected now - the install was overwriting the file. New installs were uploaded yesterday.
