send data beween applications
• Page 2 of 2 • 1, 2
Re: send data beween applications
This might work with one sender and one receiver, but you'll post this UDP into your network and every PC in there is going to receive this.
MyCo - Posts: 718
Thanks for this MyCo
I have it working quite well by getting the ip address saved as a txt file within the main exe then loaded in the second application at startup! for my uses it works well as the second exe or dll are launched from the main one!
thanks for the demo and the info MyCo!
it would be great to get the use of sockets from within ruby for this kind of thing or a more complete networking solution in FS
or how about a dedicated interoperability IO buss system so FS creations can talk and work together!
Best Regards
Jay
Best Regards
Jay
- Jay
MyCo wrote:This might work with one sender and one receiver, but you'll post this UDP into your network and every PC in there is going to receive this.
You right. But maybe there is a partial solution, depending on what bandwidth you use (what and how often you send; it's not streaming thing, yes?). If these are only some driving data (few strings per minute or less), then I would just add a mask inside FS apps, to filter received data. Not effective, but to some degree - usable I guess.
great ideas/suggestions Jay !
I have a project idea that I would like 'inter communication' between 'component' apps ... all within
a single PC. If this could be accomplished with FS, it would greatly influence my design approach.
MyCo wrote:Yeah broadcast just works with UDP, the problem with UDP is, it's a "send and forget" protocoll. So no matter what you send out, you'll never know if someone even received something.
this can also be used to send the data port ip of the server.
but you have to write a minimum of protocol question - answer.
anyway, here's Win7 on the client side I disconnected the string for ip connector,
it suppose to set the ip to 0.0.0.0 or 127.0.0.0 when it nil ?
Strange but in TCP mode it works.
digitalwhitebyte - Posts: 106
Hi all,
I was wondering if someone could help me out a bit? I'm using the "program communication (MyCo).fsm" file posted by MyCo. I set it to receive via UDP and I'm sending it OSC messages.The incoming messages will look something like this "/slider/value 0.63100". I can see the incoming messages but I can't figure out how to setup a knob within Flowstone that will change according to the value received. The values will be floats between 0.0 and 1.0.
If someone could post a couple of examples it would be greatly appreciated. One with just a single knob and perhaps a second example that would detect two different incoming messeges such as "/slider/value1" and "/slider/value2" and adjust the corrisponding knob1 or knob2.
Thank you
Thank you
- SoundGuy
I have used the network client <-> server communication. I work fine,, But is a bit complex and will not work if you have other network client <-> server communication going on!
I would use the (one exe saves data, second exe reads them) approce. The "reciever" can read the txt file like every secound for any new info from the first app. This is relativ simple to implement.
- KimSteff
I allready do the same thing, but then the 2 applications works on one PC.
First application writes the generated data.
And 2nd application reads and displays it. (the idea is to have the 2nd application on a BIG screen)
see: http://sourceforge.net/projects/bs5figh ... =directory
jjs - Posts: 142
Sending data between 2 Programs hase also been a Problem in SynthMaker - but now when flowstone got more and more Options, it was too important to me to get an running solution.
So Flowstone got the Server and Client module and i di an addon for it:
viewtopic.php?f=3&t=2215
Some monthes ago i did a similar with a variable Server that exchanges data P2P. It is also somewere here in der Forum i can not find it now
But the shematic i finished today with the Basics will work on one PC OR on more - You are able to use it local or in LAN (Also Internet would be possible with the correct WAN Settings - but the FlowStone-server-module is too unsave at the moment for those kinds of operations)
Regards
Regards
chackl - Posts: 233
