FlowStone 3.0.6 PEBBLE
• Page 2 of 3 • 1, 2, 3
Re: FlowStone 3.0.6 PEBBLE
I sent the question to Malc. Either this is a feature conflict somewhere, or there is some key/click combination for that.
As for what you just wrote - I would have to see on some video what you mean. I just placed the stock "Additive Osc", moved in edit mode with it, and tried to do something/anything with it. When dbclick on any gui part - everything gets somewhat frozen uintil next dbclick.
Good news. The old sub-module tracking behavior can be used while holdihg SHIFT when dbclick on gui parts. Just checked and it works.
ah nice but it should be diffrent way. So when holding shift you can edit the modules instead of shift jump to module. if oyu understands what i mean
- djbrynte
ahhh, great thank you tester for figuring it out!
yeh..thanks tester....this is great....really missed that feature....tired of "fishing"...
Well - these are two different functions for two different purposes (editing gui parts vs tracking data modules within workspaces), so it would be strange to remove one and replacing with another. OTOH I suggested that it might be a good idea to include in User Guide a list of keyboard / key+click shortcuts and navigational functions, so that they are in one place and easy to find. We will see in the future if this will be, but if not (or in the meantime) - someone could prepare a guide for that. I'm sure there are dozens of features we don't use on everyday basis, simply because we don't know they are there.
tester wrote:I'm sure there are dozens of features we don't use on everyday basis, simply because we don't know they are there.
Yop, the user guide is incomplete. For example "|" (logical OR) and pow() functions are still missing in the Code Component section expressions list.
Wow - wait dudes...
@nubeat7: did u try [Shift] and LDouble click???
cu
Walter
is there no way anymore to move into modules from the mainview?
there is this new feature to select the different views in the main window, before 3.05 it was possible to move into modules with a doubleclick, but now this isn't possible anymore, i mean its nice to select all viewlevels from the mainview but maybe an option in the rightclick menu to move over there would be really helpful, now i always need to dive down level for level and often in complex projects its diffcult to find what you are looking for...
cu
Walter
thank you walter, tester also figured it out.
but how did you know that? is it documented anywhere?
tester wrote:Good news. The old sub-module tracking behavior can be used while holdihg SHIFT when dbclick on gui parts. Just checked and it works.
Ooops - overlooked testers answer...
Dunno if i tried it intuitivly - but right now i found it on Page 71 in the User Guide!
keep on doing!
Walter
keep on doing!
Walter
