Why FlowStone be late in FL?
Re: Why FlowStone be late in FL?
Postby Nowhk » Fri Nov 07, 2014 12:22 pm
But that test would be futile, since has nothing to do with MIDI mgmt inside FlowStone :shock:
The problem is dealing with MIDI...
Nowhk
Postby Nubeat7 » Fri Nov 07, 2014 12:42 pm
it doesn't matter because it proofs if the plugin itself introduces any delay if it doesn't also any outgoing midimessages will be tight, beside that it tests the input of a midi sequence
you also could modify the schematic to test 2 incoming midi notes one on channel 1 and the other on channel 2, i just don't know if you could do the routing for this test in FL, one channel would have your FS vst in the chain and the other not... just an idea like ive said before i have no chance to test atm
test.fsm
(1.55 KiB) Downloaded 830 times
Postby Nowhk » Fri Nov 07, 2014 12:59 pm
With the script you've posted, the Label output 500.000 ms. Always, FL being stopped or playing...
Not sure at all if I'm doing the right test:
Nowhk
Postby adamszabo » Fri Nov 07, 2014 3:00 pm
I tested your FL studio project and I can confirm that I also get latency. I dont know why it does that, but you can use plugin delay compensation on your other mixer tracks to get them in sync.
adamszabo
Postby Nowhk » Fri Nov 07, 2014 3:08 pm
adamszabo wrote:I tested your FL studio project and I can confirm that I also get latency. I dont know why it does that, but you can use plugin delay compensation on your other mixer tracks to get them in sync.
Man, that's a pain!
This is just a simple/easy example, and there are lot of delay problems. Also because when I trigger more consecutive notes, each of them are out of sync.
Seems to be a huge problem this, working on FL. Or maybe I'm missing somethings...
Nowhk
Postby Exo » Fri Nov 07, 2014 8:05 pm
Man, that's a pain!
I would report that to Imageline and see what they say, there is no reason that Flowstone is delaying the midi (no processing). I think it is likely a problem with the integration of Flowstone into FL Studio.
Exo
Postby Nowhk » Mon Nov 10, 2014 8:53 am
Already did days ago: http://forum.image-line.com/viewtopic.p ... 0&t=132980
But maybe they will focus up more if a developer contact them ;)
Thanks for the support! Let us know when this will be fixed.
Best regards
Nowhk
Postby tulamide » Mon Nov 10, 2014 9:00 am
Unfortunately, IL is not very interested in making their product compatible, it seems. PHI also had issues with FL Studio and made posts about it. Instead of correcting their wrong output (ignoring the VST standards) to VSTs, they proposed a workaround, that will not work with VSTs depending on the standard. So I'm afraid you're pretty much lost. :(
(Of course that's highly subjective)
