Midi Controller deactivates while load (solved)
Re: Midi Controller deactivates while load
Postby RJHollins » Sat Mar 07, 2015 3:59 am
Just using the 'SELECTOR' prim.
I feed it a BOOLEAN [set by a timer] to switch the main MIDI line connection. Basically breaks the connection.
I also have a ON/OFF switch so the user can make changes WITHOUT sending any MIDI data [just one of those late nite ideas that have actually come in handy] :) What would happen when ever I UPDATED the plugin, my old chain and plug would be a mess [sometimes due to the change in preset parameters]. With the manual disconnect I could add my plugin into the chain and manually reset knobs and settings, then delete the old one. Crazy ... but it worked really well for me.
If ya need more info, just ask ... glad to share what little I know :lol:
Re: Midi Controller deactivates while load (solved)
Postby clemens » Wed Mar 11, 2015 10:46 pm
Problem solved !
The Preset File was just to long. We´ve reduced it to a minimum with some ENgine Optimization and Boom ! We´re good to go now !
In Bridged Mode and in 64Bit Mode in Cubase 8 and Windows at it´s also running perfectly !
clemens
