Setup priority on MIDI Execution - Delay?
Re: Setup priority on MIDI Execution - Delay?
Postby nix » Wed Apr 29, 2015 8:43 pm
It's fine to delay triggers-
even MIDI(with Ruby) I imagine.
It's not necessary here though, the link order thing should be fine IMO
If the changes are too fast, and it doesn't work right,
you can introduce a 'timer' if needed, on the trigger
Nice idea
nix
Postby Walter Sommerfeld » Thu Apr 30, 2015 1:51 pm
maybe the R&D primitive: Midi Buffer
could help here...
Flush the second buffer after a short delay?!
Walter Sommerfeld
Postby KG_is_back » Thu Apr 30, 2015 2:38 pm
You may use Ruby, to order midi messages in specific order, if they arrive at the same time.
For example this code will accumulate all note on and note off messages that arrive at the same time and order them properly, that all note on preceed note off. Other messages (like CC) are simply passed as they are
input midiIn, output midiOut
def init
@noteon=[]
@noteof=[]
def event i,v,t
if i==0 #ariving messages
   midi=@in.to_array
   if midi[0]==144
       @noteon << midi
       input 99,nil  #schedule buffers emptying after all notes are received
   elsif midi[0]=128
      @noteof<< midi
   else
   output @in
elsif i==99 #clear buffer
@noteon.each{|note|
output Midi.new(note[0],note[1],note[2],note[3])}
@noteof.each{|note|
@noteon=[]
@noteof=[]
