Tuned Noise Gen (.. but not as we know it Jim)
Re: Tuned Noise Gen (.. but not as we know it Jim)
Postby wlangfor@uoguelph.ca » Mon May 25, 2020 9:11 pm
this is one of the most amazing things I've ever heard, amazing. Thanks :)
My youtube channel: DSPplug
Postby Spogg » Tue May 26, 2020 8:01 am
Very nicely done Hugh (all in one ASM box). :ugeek:
I suspect, but I don’t know, that we don’t need such a sophisticated sinewave generating code just to make use of the method to make pitched noise. Martin’s original code aimed for a perfect sinewave, but for noise it may be overkill…
Postby HughBanton » Tue May 26, 2020 10:07 am
You're right, we don't .. turns out it works just as well with triangle oscillators in positions 2 & 3 - they're half the code. Yay. But with a sin osc in position 1 we seem to get this really clean bandlimited output.
I'll carry on with it while it's got my attention, back later perhaps. (What else am I going to do ... ? :lol: )
H
HughBanton
Postby HughBanton » Wed May 27, 2020 5:28 pm
And finally ..
I was slightly wrong about about using triangles for oscs 2 & 3 - they introduce higher harmonics so the roll-off isn't as good. Obvious when you think about it. The way I had the design originally I reckon it produces an almost 'analogue' sound. (Whatever that's supposed to mean. :roll: .. I blame the heat).
So I've been investigating alternative, more compact, sine generators. I've researched several of MVs extensive collection of algorithms, both FS and published elsewhere - amazing resource - but found all the '2- or 3-liners' were unstable in this application, and it generally lost the plot after a few seconds.
Polynomial oscillators, I've learned this week, use a relatively simple formula to convert a regular ramp (saw-tooth) into another function, in this case a cosine. So because they start with a predictable straight-line counter they're really stable. Martin will be horrified at my maths-hacking, but I discovered I could remove the c3 constant, adjust both c1 & c2 by trial and error, and get a sufficiently cosine-ish result that seems acceptable. Which shortened each of the 3 oscillators by several lines of code. (DSP version is in the 'Polynomial Osc (HB reduction)' modules).
So here we are, reduced version. I doubt it will go any more compact than this, but I'd bet this now compares favourably with the noise + extreme filter that would be required to get this sound by the traditional method.
Snag is you can't adjust the roll off, as far as I can tell .. but maybe people can find a use for it as is.
By the way .. my original "woke up this morning" idea last Sunday was in fact for a blue mono LF random generator, not a poly noise generator at all. I've long been aware that if you get a pendulum (mathematically predictable) but insert a hinge at some point along its length, the resulting movement rapidly turns to .. Chaos. So I was aiming to emulate a 'hinged-pendulum' setup. Funny where things lead sometimes ...
H
osc_ring_assem_2.fsm
(17.74 KiB) Downloaded 968 times
PS Thanks Spogg for the 'Uber Geek' yesterday - never expected to earn one of those, you made my day!! ('Unter Hacker' more like ....)
HughBanton
Postby wlangfor@uoguelph.ca » Wed May 27, 2020 6:34 pm
Amazing, simply amazing :)
Postby k brown » Wed May 27, 2020 7:09 pm
I certainly don't follow the maths at work here, but just going by what I hear, it doesn't sound any different from white noise thru a filter with 100% keytrack. Is the whole point that this uses a lot less CPU than noise gen-plus-filter? Is there something I'm missing?
Postby wlangfor@uoguelph.ca » Wed May 27, 2020 10:55 pm
k brown wrote:I certainly don't follow the maths at work here, but just going by what I hear, it doesn't sound any different from white noise thru a filter with 100% keytrack. Is the whole point that this uses a lot less CPU than noise gen-plus-filter? Is there something I'm missing?
He just doesn't understand.. "shakes head
Postby k brown » Wed May 27, 2020 11:19 pm
Well, 'splain it to me - that's why I posted; how does this sound different?
Postby Spogg » Thu May 28, 2020 7:38 am
Well done again Hugh! :ugeek:
@Kevin
Yes it’s all about CPU versus flexibility. With a filter system you still need to produce the noise in the first place, and that can be done with one sine osc with a high amount of self-feedback for phase or frequency modulation. That creates noise which is kinda white, probably sufficiently so. But if you want key-tracked filtering you of course need a filter and the tracking system, and a decent filter will use a lot more CPU than two more optimised sine wave oscillators (I think!).
But if you want flexibility in terms of resonance, slope and mode then the traditional noise-filter arrangement is the only way. So it depends on the application. I suspect in Hugh’s case for example, he might find it useful for simulating the turbulence you get when an organ pipe speaks, since that sound will inevitably be related to the pitch of the pipe.
Postby k brown » Thu May 28, 2020 7:58 am
That's what I figured - a CPU-light way of getting a similar result. Could be useful as an additional osc 'waveform' in a synth -leaving the main Noise gen for other things and not tying up the filter.
Possibly flute 'chiffs' as well.
