Help Johan with Rompler expansion system
Re: Help Johan with Rompler expansion system
Postby wlangfor@uoguelph.ca » Mon May 25, 2020 9:09 pm
you don't need anything like that, infact for just the wav files you don't even need a fancy preset. In fact a float 0-1 is all you need for the preset.
Look at My example here:
https://vstplug.com/downloads/flowstone-sampler-components/
What it does is look for a root folder, which you have saved as a .txt file, but that's the only thing you need to load as txt for the preset. Next, all you need to do is list the folders sorted alpha numerically. This is so that they arranged 0-1.
So, if you make expansions, number the file or folder:
1-expansion name
2-expansion name
and that way they will always have the same order and it's just a matter of 0-1 being multiplied by 0.001 or whatever so that you can make a smaller finite number that will allow you the possibility of many categories.
It's the easiest solution. And furthermore; to load more preset data for just that preset, those instructions can lay inside that folder if you wish to be fancier.
My youtube channel: DSPplug
Postby djbrynte » Tue May 26, 2020 2:40 am
So many helpers here im so Lucky for your support.
And thnx spogg for correcting my english etc.
Anyway i have a question to some one here Who knows how to do it.
Can any one pls help me to do this into The rompler? I Will ofc give you credits in The rompler and on The site as a promisse. Because this is above my skillz and I admit it.
djbrynte
Postby djbrynte » Tue May 26, 2020 2:42 am
And Also If I post News about The VST at kvr i Will mention your name with Rex. And The rompler is going to be free. Only thing that Will cost is The expansion packs for cheap amount of money.
djbrynte
Postby kortezzzz » Tue May 26, 2020 7:16 am
Johan, I guess you'll have to upload at least one schematic to let us see what's going on inside and how the loading routine works. It would be difficult suggesting things in theory. Or just choose at least one forum member which you trust of and send to him. Every schematic has it's own special structure. It gonna be hard task to suggest solutions only from the imagination.
kortezzzz
Postby djbrynte » Tue May 26, 2020 1:33 pm
oh sry here is the shematic.
djbrynte
Postby tulamide » Tue May 26, 2020 9:15 pm
djbrynte wrote:oh sry here is the shematic.
Now if you would actually supply one... :lol:
Postby djbrynte » Tue May 26, 2020 10:45 pm
I posted it wtf.
Anyway i talked to Rex and we tested all this.
He told me it only works for me and not The others or something.
Correct me If im wrong Rex.
But mybe tula is up to something Rex told me mybe a ruby solution Will be something.
djbrynte
Postby djbrynte » Wed May 27, 2020 10:57 am
Rompler for tulamide
Can u help me also so it starts on start library eveytime u open the rompler or start with the latest used library/expansion.
djbrynte
Postby wlangfor@uoguelph.ca » Wed May 27, 2020 6:49 pm
I'd be glad to post a complete solution to solve this dillemma and will. But I was troubleshooting last night and there's the new bug with acoustica mixcraft 9 not allowing fonts to worry about :/. Lordy i am busy.
Postby wlangfor@uoguelph.ca » Thu May 28, 2020 2:30 pm
Ran out of time sorry, tomorrow for sure :)
