OS version module
Re: OS version module
Postby nix » Fri Nov 01, 2013 12:28 am
If you need this RJ,
it works on 8.
Can see if it delivers 8.1 in 2 weeks,
I haven't the bandwidth to upgrade this fortnight.
32/64 bit displayed might be handy too
nix
Postby Mo » Fri Nov 01, 2013 1:40 am
Great, here it is with system type.
OS_finder4_Mo.fsm
(1.74 KiB) Downloaded 944 times
Mo
Postby nix » Fri Nov 01, 2013 1:55 am
ty!
it's working on my 8 64-bit
this one gets filed away for sure-
I'm not exactly sure what I would like to do with it,
but well done 8D
nix
Postby RJHollins » Fri Nov 01, 2013 2:03 am
very cool !
Yeah, same here ... not sure when ... but great to have just in case.
Actually, I never knew this was possible ... what else might be in there :o
Postby CoreStylerz » Fri Nov 01, 2013 2:34 am
Mo it says im using windows vista, while im running 8.1... :o
PM me if you are interested.
CoreStylerz
Postby Mo » Fri Nov 01, 2013 3:28 am
CoreStylerz wrote:Mo it says im using windows vista, while im running 8.1... :o
Ok, that's weird. Can you post the text file c:\Users\User\AppData\Roaming\ver.txt
Mo
Postby Mo » Fri Nov 01, 2013 4:16 am
RJHollins wrote:what else might be in there
Here is the complete system information. :)
SystemInfo_Mo.fsm
(2.41 KiB) Downloaded 934 times
Mo
Postby RJHollins » Fri Nov 01, 2013 6:07 am
:shock: :shock: :shock:
wow .... that is MO than I expected.
:lol:
Thanks MO !! 8-)
Postby CoreStylerz » Fri Nov 01, 2013 1:15 pm
Nome host: TC-STUDIO
Nome SO: Microsoft Windows 8.1 Pro con Media Center
Versione SO: 6.3.9600 N/D build 9600
Produttore SO: Microsoft Corporation
Configurazione SO: Workstation autonoma
Tipo build SO: Multiprocessor Free
Proprietario registrato: TheCoreStylerz
Organizzazione registrata:
Numero di serie: XXXXX
Data di installazione originale: 17/10/2013, 23.27.18
Tempo di avvio sistema: 01/11/2013, 11.52.29
Produttore sistema: System manufacturer
Modello sistema: System Product Name
Tipo sistema: x64-based PC
Processore: 1 processore(i) installati.
[01]: Intel64 Family 6 Model 58 Stepping 9 GenuineIntel ~2700 Mhz
Versione BIOS: American Megatrends Inc. 2204, 23/08/2013
Directory Windows: C:\WINDOWS
Directory di sistema: C:\WINDOWS\system32
Dispositivo di avvio: \Device\HarddiskVolume1
Impostazioni locali sistema: it;Italiano (Italia)
Impostazioni locali di input: it;Italiano (Italia)
Fuso orario: (UTC+1.00) Amsterdam, Berlino, Berna, Roma, Stoccolma, Vienna
Memoria fisica totale: 8.140 MB
Memoria fisica disponibile: 6.267 MB
Memoria virtuale: dimensione massima: 16.332 MB
Memoria virtuale: disponibile: 13.822 MB
Memoria virtuale: in uso: 2.510 MB
Posizioni file di paging: C:\pagefile.sys
Dominio: WORKGROUP
Server di accesso: \\MicrosoftAccount
Aggiornamenti rapidi: 15 Aggiornamenti rapidi installati.
[01]: KB2859675_Microsoft-Windows-CameraCodec-Package
[02]: KB2882351
[03]: KB2883200
[04]: KB2884101
[05]: KB2884846
[06]: KB2886439
[07]: KB2889543
[08]: KB2891214
[09]: KB2894029
[10]: KB2894179
[11]: KB2895219
[12]: KB2898742
[13]: KB2901549
[14]: KB2902892
[15]: KB976002
Schede di rete: 2 NIC installate.
[01]: Realtek PCIe GBE Family Controller
Nome connessione: Ethernet
Stato: Supporto disconnesso
[02]: NETGEAR WNA1100 N150 Wireless USB Adapter
Nome connessione: Wi-Fi
DHCP abilitato: S
Server DHCP: 192.168.0.1
Indirizzi IP
[01]: 192.168.0.3
[02]: fe80::ddc9:1189:38d3:c7c6
Requisiti Hyper-V: Estensioni modalit… di monitoraggio macchina virtuale: S
Virtualizzazione abilitata nel firmware: No
Conversione indirizzi di secondo livello: S
Prevenzione esecuzione dati disponibile: S
CoreStylerz
Postby Mo » Fri Nov 01, 2013 1:51 pm
Thanks but it seems you have posted the "sys.nfo" file from SystemInfo_Mo.fsm instead of "ver.txt".
Well, I think this'll fix it:
OS_finder5_Mo.fsm
(1.74 KiB) Downloaded 936 times
Mo
