Is it possible to build a very simple SFZ creator?
Re: Is it possible to build a very simple SFZ creator?
Postby mccy » Thu Jan 17, 2013 10:51 pm
not a big problem. I seem to have a workaround... maybe...
The good part of the story: I now understand, what "regular expressions" (as you suggested right in the beginning) mean for my little project. Maybe I get the work done with them.
mccy
Postby mccy » Fri Jan 18, 2013 8:36 am
Workaround didn't work, so you have to open *.txprog in notepad & save it as utf8 first.
Maybe I'll make a pure rubyscript for converting whole directory in the end. That would be a nice handling.
With these regex lines it gets the first sample & overall zone + vel. Best thing: IT WORKS AS SFZ!
Even the utf8 file works in tx16wx as I remember... but that is not important anyway.
Now I have to look into (how was it called?) blockediting and string-scan. Hope I get it, how to work with arrays.
Then with no further big problems it should be no deal, to get a simple sfz zoning from txprog!!!
sfzwithutf8.fsm
(560 Bytes) Downloaded 1134 times
mccy
Postby mccy » Fri Jan 18, 2013 8:59 am
HA! That is easy :lol: :D :mrgreen:
mccy
Postby mccy » Fri Jan 18, 2013 9:47 am
To test: extract zip to c (it makes folder sfztest)
Finally I have to create a loop for processing all findings in array, to get all keygroups.
And one for writing all data found in the sfz file...
No idea, how this will be done... :roll:
sfztest.zip
(1.85 KiB) Downloaded 1083 times
mccy
Postby mccy » Fri Jan 18, 2013 4:16 pm
nearly finished ...
mccy
Postby mccy » Fri Jan 18, 2013 5:58 pm
Tadaa!
So I guess, in a few weeks this will be a really nice tool...
tx16wxtosfzconverter05.fsm
(2.84 KiB) Downloaded 1102 times
mccy
Postby Jay » Fri Jan 18, 2013 6:01 pm
looks great! i don't use the synth who's file format you are converting from and had never heard of it until your thread appeared! but there is stuff to learn from your work for sure! :D
you could do a version that parses a folder of key named waves and assign them to key ranges and place them in a SFZ file! that would be real cool! kinda like an auto SFZ maker!
Best Regards!
Jay
Postby mccy » Fri Jan 18, 2013 6:12 pm
That's exactly, what TX16WX (freeware) does in the best way I could imagine...
Just recognized that rootkeys are not working so far in my converter.
mccy
Postby mccy » Fri Jan 18, 2013 6:21 pm
thisone should do with rootkeys...
tx16wxtosfzconverter05b.fsm
(2.86 KiB) Downloaded 1047 times
mccy
Postby mccy » Sat Jan 19, 2013 12:28 am
Wow. It's more difficult than I thought. But working better and better. When selecting a bunch of samples and splitting in to groups (or with one big group) old version didn't work. Now this seems to be O.K.
tx16wxtosfzconverter06c.fsm
(9.96 KiB) Downloaded 1091 times
mccy
