home brew sequencer
Re: home brew sequencer
Postby billv » Wed Apr 17, 2013 7:39 am
Re-directing "Timing issue" over to "Test ticking" post.
viewtopic.php?f=2&t=1268
Let this one stay with Home Brew Seq and the Ruby Counter quest.
nix wrote:But I thought use might like 'changed' in a single code block->
Thanks mate. In the toolbox. Cheers.
billv
Postby daslicht » Mon Apr 06, 2015 5:23 pm
Anyone managed to create a step sequencer which syncs to midi ?
daslicht
Postby Perfect Human Interface » Mon Apr 06, 2015 11:49 pm
daslicht wrote:Anyone managed to create a step sequencer which syncs to midi ?
Try using the PPQ prim.
Postby nix » Wed Apr 08, 2015 4:37 pm
yeah- the timing isn't that bad,
it even spits out the ruby midi green conversion without audio discontinuities in a simple app.
If you want to sync to MIDI- maybe draw a bar long note,
and use that to start your sequence.
It will only wander for that bar length,
and host will determine that the sequence starts again.
Some hosts have pretty cruddy timing i.e. Usine is a little wonky-
but these slight errors really make no difference to musical creativity
nix
