Camouflaged Switch with Hidden Help Menu (or Registration Menu):
I call it 'camouflaged' since the switch is not really 'hidden'. What I mean by camouflage is that you can load an image into the switch bitmap loaders which contain your own ideas (i.e. for example a hor/vert line, a screw head, an icon etc) which can form part of the front panel of your schematic to serve (for instance) as a secret registration button which must be hovered/clicked on with the mouse cursor prior to entering the registration details into the hidden registration window. The switch/push button can also serve the purpose of displaying a hidden help menu for a specific push button when the mouse cursor hovers over that button...(just some ideas).
Camouflaged Switch & Hidden Help Menu.fsm- (18.02 KiB) Downloaded 1348 times
tiffy - Posts: 400
Hidden Switch with Hidden Pop-up Help Menu (or any other purpose you can think of):
The name says it all. Hovering the mouse cursor over the hidden switch will cause the hidden Pop-up Menu to be displayed. The Switch have a Click function as well that you can use for some other purpose.
Hidden Switch & Hidden Help Menu.fsm- (12.58 KiB) Downloaded 1285 times
tiffy - Posts: 400
fun stuff !
Thanks TIFFY
Thanks TIFFY
3-Stage Sequence & Time Interlock:
This is used to Start/Stop other schematics/Items in the correct sequence.
A short description is inside the schematic.
3-Stage Sequence and Time Interlock.rar- (89.03 KiB) Downloaded 1520 times
tiffy - Posts: 400
I was inspired by a schematic which Billv uploaded some time ago i.e. "cheating the Mouse" and I thought that it was really cute, so I decided to see if I can build such a schematic with similar (not necessarily the same) characteristics without studying or copying any of his schematic. So, here is the result of my version of it.
At this stage it is just a fun thing, but I have the feeling that somewhere along the lines I am going to need this in another larger schematic - I believe that every functioning schematic has a purpose.
A short description of how the circuit should function is inside the schematic.
# There is a typo in the description which should read: "If you Drag the mouse Cursor past the Display Window View Area boundaries, the Mouse LUp (and Not LDown) will not be captured and the Mouse will not be released."
Cheating the Mouse LUp Button2.fsm- (34.76 KiB) Downloaded 1330 times
tiffy - Posts: 400
Electric Motor Emulation (Ruby):
As the name implies.
I wanted to do the schematic entirely in Ruby but to my surprise there is no instruction in Ruby for "Rotating" lines about an axis, although one can Rotate images. Anyways...
Electric Motor Emulation (Ruby).fsm- (45.51 KiB) Downloaded 1388 times
tiffy - Posts: 400
BRASS PENDULUM v2 (Ruby):
Pendulum follows characteristic of a Sine wave.
You can adjust the speed as well as the angle.
For default settings, Ctrl + LDo Click on the two Knobs.
Clock Pendulums normally swing between 2-4 Degrees.
For operation, switch on the Ticker as well as DS Out primitive Primary Sound Driver.
Brass Pendulum v2 - Ruby.fsm- (31.47 KiB) Downloaded 1313 times
tiffy - Posts: 400
tiffy wrote:to my surprise there is no instruction in Ruby for "Rotating" lines about an axis, although one can Rotate images. Anyways...
Because rotating points is pretty simple. The toolbox of my Spline class provides you with methods to rotate points (and therefore lines), move along an angle and such.
tulamide wrote:tiffy wrote:to my surprise there is no instruction in Ruby for "Rotating" lines about an axis, although one can Rotate images. Anyways...
Thank you, I will have a look at it.
tiffy - Posts: 400
tiffy wrote:tulamide wrote:tiffy wrote:to my surprise there is no instruction in Ruby for "Rotating" lines about an axis, although one can Rotate images. Anyways...
I don't know if you need more help, but just in case I made a post about rotating points: http://www.dsprobotics.com/support/viewtopic.php?f=3&t=4350
