Tulamide wrote:
I don't know if you need more help, but just in case I made a post about rotating points: http://www.dsprobotics.com/support/viewtopic.php?f=3&t=4350[/quote]
Thank you Tulamide,well presented maths. However, the test (for myself) will be when I have to put that knowledge into one ruby code module. Will test it later on.
tiffy - Posts: 400
HIDDEN SELECTOR SWITCH WITH HIDDEN TOOL TIP:
When the Mouse cursor hovers over the Selector switch area, the hidden Selector switch will show up in the switch area and at the same time the hidden Pop-up Tool tip will be displayed. Click with Mouse cursor on Selector Switch to select an item.
Hidden Selector & Tooltip.fsm- (4.18 KiB) Downloaded 1368 times
tiffy - Posts: 400
SYNCHRONIZING CERTAIN ITEMS IN CERTAIN VIEWS:
The title tells it all.
Synchronize Certain Items in Certain Views.fsm- (83.8 KiB) Downloaded 1369 times
tiffy - Posts: 400
Ya know ... there will be that time that these will prove so useful !
Thanks TIFFY
Thanks TIFFY
INHIBITOR SWITCH (RUBY & with PRIMITIVES)
Included is also an example of how to use the Inhibitor as a Mute in a Stereo Audio Amp.
Inhibitor Switch (Ruby and Primitives).fsm- (148.94 KiB) Downloaded 1367 times
tiffy - Posts: 400
3D-KNOBS (BITMAP) x 4:
SOME OF THE CHARACTERISTICS OF THE KNOBS:
Most knobs that I specifically post under the heading "knobs" will have these main characteristics which is -
1) Ctrl + LDo Click will reset knob to predefined Default position (Currently set to 0.5) which can be set in the Properties Menu.
2) Function to Hold & Hide cursor in same position whilst dragging the mouse cursor to adjust knob.
3D-Knobs x 4.fsm- (1.54 MiB) Downloaded 1397 times
tiffy - Posts: 400
4 - DIFFERENT WAYS OF OBTAINING SIMILAR OUTPUT SWITCHING RESULTS BY MEANS OF A "SELECTOR", A "GETAT", A "INDEX SELECTOR" AND A "SELECTOR WITH DROP LIST."
However, each may have its own specific application as well, as in the case with the 2nd GETAT shown in the schematic in which case the SELECTOR won't do as a substitute. The same applies to the "Selector" Primitive, there are applications where the "GetAt" Primitive will not work as a substitute.
In many instances I personally prefer (but opinions differ) the GETAT Primitive in this type of application instead of the SELECTOR Primitive since it has less components and it makes the schematic to appear neater - especially when there are many inputs.
4 - DIFFERENT WAYS OF OBTAINING SIMILAR OUTPUT SWITCHING RESULTS.fsm- (10.74 KiB) Downloaded 1371 times
tiffy - Posts: 400
LAST SWITCH (RUBY)
Description inside module.
Last Switch (Ruby).fsm- (475 Bytes) Downloaded 1357 times
tiffy - Posts: 400
EVENT DELAY (RUBY)
Event Delay (Ruby).fsm- (1.25 KiB) Downloaded 1339 times
tiffy - Posts: 400
SAMPLE & HOLD (RUBY)
Sample & Hold (Ruby).fsm- (529 Bytes) Downloaded 1350 times
tiffy - Posts: 400
