Postby Nubeat7 » Wed Jun 15, 2016 8:30 pm
you can exchange the ticker with the old version which should be in your toolbox..
Postby RJHollins » Thu Jun 16, 2016 6:20 am
ah ... ok.
I replaced the 'ticker' module, and all is working.
I fed the 'state' Boolean into the stock 'ticker' module and everything starts and re-sets nicely.
Also changed the LED to GREEN when active.
Postby tiffy » Thu Jun 16, 2016 8:48 am
RJHollins wrote:ah ... ok.
Glad your (my) problem is solved mate. However, I would still like to have a look at the old Ruby Ticker code just to see where the difference is between the old & the new. Would it be inconvenient to ask you to post the old Ruby ticker here, as I don't have a copy of v3.0.4 ?
Thanks for the help from Tulamide & Nubeat7.
tiffy
Postby RJHollins » Thu Jun 16, 2016 5:55 pm
Absolutely !
Here is the Graphics CountDown schematic you posted, with my changes.
Graphic Count Down Timer (Ruby) v3.fsm
(35.91 KiB) Downloaded 1218 times
Postby tiffy » Fri Jun 17, 2016 11:10 am
RJHollins wrote:Absolutely !
Thank you, appreciate.
tiffy
Postby tiffy » Mon Jun 20, 2016 4:36 pm
ONE DROPLIST ONLY (RUBY) + 2 x SELECTORS WITH DROP LISTS (RUBY):
Please note that the two Ruby Selectors are not exactly the same as the one has a static label and the other a dynamic label which corresponds to the item selected. The Ruby Drop List Only has intentionally no background and can be used as a hidden Drop list.
I don't know if anyone noticed that the previous Ruby Selectors & Ruby Drop List I uploaded to the DSP Forum some time ago, although they all retained their settings the setting displayed on their Drop lists reverted to 0 after a shutdown and a restart of the schematic.
So, that bug were fixed in this upload and I think the schematics is also a bit neater.
Droplist + 2 Selectors (Ruby).fsm
(6.11 KiB) Downloaded 1211 times
tiffy
Postby Nubeat7 » Mon Jun 20, 2016 6:26 pm
there are a few things to say about..
1. to place a redraw inside the draw methode forces an endless redraw loop
2. if you redraw inside ruby, no extra redraw primitives are needed
3. "d = @inside ? 20:0" - no variable of this line is used..
4. "output 2,v.height" - there is no output 2
5. it is a useless overload, to load all pc fonts on each start of the app, you can purgeable this
6. the init methode - @index = @index - better check if nil or?
7. preset management would be helpful too
i also wouldn't initialise "b" 2 times because it is confusing to have one variable which does 2 different things in one methode..
ps: you don't need to delete everything again, i stopped commenting your stuff, this is just an exception, because i'm bored, i promise ;)
Postby tiffy » Fri Jan 27, 2017 11:43 pm
RUBY RANDOM NUMBER GENERATOR (FROM A RANGE).
I am not sure if this is the best Ruby method I used for the Random Number Generator, however I tried to keep the Ruby Code as simple and as short as possible.
So, please first test it before using it in any application.
RandomNumberGenerator (Ruby).fsm
(4.97 KiB) Downloaded 1145 times
tiffy
Postby Spogg » Sat Jan 28, 2017 9:13 am
Hey tiffy that's great and gone into my toolbox!
Postby tiffy » Sat Jan 28, 2017 10:33 am
RUBY RANGES:
Ruby supports ranges and allows us to use ranges in a variety of ways:
1) Ranges as Sequences
2) Ranges as Conditions
3) Ranges as Intervals
Just in case someone wonders what the "range.to_a" method (convert a range to a list) does in the Random Number Generator I posted previously, here is a link that explains it quite well:
https://www.tutorialspoint.com/ruby/ruby_ranges.htm
tiffy
