Filled circle with circular gradient in ruby
Postby tester » Sat Dec 30, 2017 11:49 am
Could someone post how to draw a circle/ellipse in ruby, that is filled with circular gradient? (one color in the center, other color outside). I'm confused a bit with the manual - it speaks on multipoint/coordinate gradients for polygons; I just need a simple ruby replacement for circle drawing prims.
Re: Filled circle with circular gradient in ruby
Postby adamszabo » Sat Dec 30, 2017 12:11 pm
try this:
def draw v
c1 = Color.new 0,35,247
c2 = Color.new 210,34,67
r = [2,2,12,12]
p = GraphicsPath.new
p.addEllipse r
b = PathGradientBrush.new p
b.setSurroundColors [c1]
b.setCenterColor c2
b.setCenterPoint 8,8
b.setBlend [[0,0],[1,1],[1,1]]
v.drawEllipse b,r
adamszabo
Postby tulamide » Sat Dec 30, 2017 1:19 pm
adamszabo wrote:try this:
def draw v
r = [2,2,12,12]
p.addEllipse r
b.setCenterColor c2
v.drawEllipse b,r
:o You've become a real pro at Ruby!
Postby adamszabo » Sat Dec 30, 2017 2:02 pm
tulamide wrote: :o You've become a real pro at Ruby!
Haha, nah im still far from that :D
adamszabo
Postby tester » Sun Dec 31, 2017 11:34 am
Hey Adam, basically I need to integrate it into something like this. the csiz is diameter (2r). Center should have one color, and outer - second color.
drawingdots.fsm
(635 Bytes) Downloaded 960 times
Postby tulamide » Sun Dec 31, 2017 12:53 pm
You mean the equivalent of the prims "Ellipse" and "Filled Ellipse"?
Just use a pen for outlines with :drawEllipse
and a brush for fills with :drawEllipse
Flowstone user guide, page 158+ for more information.
Postby tester » Sun Dec 31, 2017 10:38 pm
tulamide - may I ask you to not participate in topics, in which I'm OP? Thank you.
Postby tulamide » Sun Dec 31, 2017 11:24 pm
tester - of course you may ask. What I do or not do is not up to you, but I'm glad you show your animosity, for whatever reason. You're welcome!
Postby Spogg » Mon Jan 01, 2018 11:13 am
tester wrote:tulamide - may I ask you to not participate in topics, in which I'm OP? Thank you.
Speaking as a moderator I don’t think it’s acceptable to bar anyone from responding to a topic. A member posting here always has the option of not responding to a comment, for any reason.
If a post is considered to be unacceptable, for any reason whatsoever, please report it, with a reason, and a moderator will review the content.
In this particular instance I can’t judge the technical aspect of tulamide’s post but it may be useful to others following the subject.
As I’ve come to say lately, let’s keep it sweet guys!
Postby tester » Mon Jan 01, 2018 2:16 pm
Spogg, as a moderator - should you interfere at this point? Tricky question, isn't it?
Let say, that my motivation is a non-strict parallel to someone else who was recently pretty active on the forum.
I bet this thread is dead now.
