7seq.digi Display on Pidgets 64LED Board
Postby frank-riedel » Tue Dec 11, 2012 12:34 am
Hi All
Can anybody show me an example on "how to" connect an array of 4 or more...
7 SEQ. Displays on a Phidgets 64 LED board??
Regards
Frank
frank-riedel
Re: 7seq.digi Display on Pidgets 64LED Board
Postby frank-riedel » Thu Dec 13, 2012 11:10 pm
NoOne played with that ??
/Frank
frank-riedel
Postby MyCo » Fri Dec 14, 2012 3:34 pm
What seg display do you want to use? Give me a link to a datasheet, and I tell you how to do it, if it is possible.
MyCo
Postby frank-riedel » Fri Dec 14, 2012 5:04 pm
http://docs-europe.electrocomponents.co ... 025c0b.pdf
You are my fdriend ;)
I know about the transistor connection metode to select the display for input and array setup...
but im also interrested to see exampels on driving on output on leg of the display
THANKS ALOT
Frank
frank-riedel
Postby MyCo » Fri Dec 14, 2012 6:25 pm
I've had a look, here is the thing:
1. You can only use the Seg. Versions that have a 1 at the end of their part number, something in this format: HDSP-U__1
2. For Red and Yellow versions of this Seg. you should think about using a protections resistor. But it might not be required, because the phidget drives the LEDs in multiplexing mode, so the LEDs only see current peaks.
I'll sketch something together...
MyCo
Postby support » Fri Dec 14, 2012 7:40 pm
Had a quick look at the Phidgets led 64 manual and it says you can connect the leds directly to the board (no resistor).
http://www.phidgets.com/docs/1031_User_Guide
So I guess the hardest part is writing to all of those individual addressed leds.
Try this (not tested) but should get you going:
Ruby Seven Segment Display clip.png (46.1 KiB) Viewed 27469 times
Ruby Seven Segment Display.fsm
(2.18 KiB) Downloaded 1124 times
If you wire them up like this:
LED - Segment
0 - a
1 - b
2 - c
3 - d
4 - e
5 - f
6 - g
7 - dp
support
Postby frank-riedel » Fri Dec 14, 2012 7:57 pm
YOU ARE MY MAN . . . From here i can have a nice weekend.... i´ll be back
Merry Christmas
Frank
frank-riedel
Postby frank-riedel » Fri Dec 14, 2012 7:58 pm
YOU ARE MY HERO ;)
I have something to play this weekend... I'll be back...
Merry Christmas
Frank
frank-riedel
Postby MyCo » Fri Dec 14, 2012 8:02 pm
You can connect them directly, but then you drive the seg with overcurrent. And as long as you don't know the pulse length that this phidget thing uses, you should avoid that. In my plan, I wouldn't use the connectors 0-7, because the the seg is common anode, and every even LED-Port on the phidget is one anode, and every odd LED-Port is another anode. So I would use 0,2,4,6,8,10,12,14 or 1,3,5,7,9,11,13,15 for one display.
MyCo
Postby support » Fri Dec 14, 2012 8:28 pm
MyCo wrote:You can connect them directly, but then you drive the seg with overcurrent. And as long as you don't know the pulse length that this phidget thing uses, you should avoid that. In my plan, I wouldn't use the connectors 0-7, because the the seg is common anode, and every even LED-Port on the phidget is one anode, and every odd LED-Port is another anode. So I would use 0,2,4,6,8,10,12,14 or 1,3,5,7,9,11,13,15 for one display.
You won't over current them as the are current limited in the Phidgets Module. There is a current limit input on the FlowStone module, these don't use PWM but use active current limiting ( see Manual). Each of the 64 channels are the same and have an anode and a cathode input (two per connector). However I've not see in the manual which is active, but these devices are usually pull down so if this is the case then a common anode display should work.
support
