Newbie question how to export 64 VST ??
i,m new here and i use version 3.08.1
i didn,t find any 64 bit check while exporting vst.
but i found some one made that
http://flowstoners.com/wp-content/uploa ... v1.018.zip
how to make that?????
- alswefi
Re: Newbie question how to export 64 VST ??
64-bit export of plugins is only available in 3.09 beta versions of FS (aka FS4).
I believe it is only available to licensed users of FS, or if i'm not mistaken also licensed users of the old Synthmaker 2.0 on a testbasis.
Anyone correct me if i'm wrong here.
Note:
If you purchase Flowstone...
As a newbie myself I would not recommend using FS 3.09 betas, other than for exports of 64-bit plugins. Since it is a beta version, subject to changes.
Note:
- R&R
alswefi wrote:i,m new here and i use version 3.08.1
FS4 has been a long time in development and we have a Discord server for those who wish to participate in testing the latest alpha releases. You should own a license for FS3 or SynthMaker and be familiar with FlowStone. The familiarity requirement is to avoid having to answer basic questions on Discord which are much better dealt with here.
If you fit with the above, I can send you an invitation…
I should also mention that we recommend FS 3.06 for various reasons and if you’ve already made stuff in 3.08.1 you can open it in 3.06.
Spogg - Posts: 3327
Spogg wrote:FS4 has been a long time in development and we have a Discord server for those who wish to participate in testing the latest alpha releases. You should own a license for FS3 or SynthMaker and be familiar with FlowStone. The familiarity requirement is to avoid having to answer basic questions on Discord which are much better dealt with here.
Hallo, i m fitting these conditions too. Can I get the invitation please? I was on slack alpha channel also and have many projects in x64. Will be very happy to play in DAW with them, exported from the latest alpha.
hardwarehost - Posts: 37
hardwarehost wrote:
... Can I get the invitation please? ...
Sent!
Spogg - Posts: 3327
Hi, hopefully i am on the right place here to get an ivitation to the FS4 Alpha.
- MelodicStylez
