Program closes/crashes when closing the parameter
Hello FlowStone Frends,
I'm newby FlowStone. I use Version 3.0.9 Beta 2.
Maybe this case was mentioned but I don't find it.
Fault description:
When I call module parameter und after modification click (x) or click beside the module, program crashed and closed.
Is there any solution for proper working?
Thank you very much in advanced.
Fault description:
- adickalvidi
Re: Program closes/crashes when closing the parameter
Hello and welcome to the forum!
The 3.09 betas were found to have many issues and have now been removed from the download section.
We users strongly recommend using version 3.06.
Have fun!
Have fun!
Hello Spogg,
thank you for the quick response.
I created several projects with V3.0.9 Beta 2. Actually this version contains many bugs, so I diceid to switch to the old version V3.0.8.1
is it possible to open/edit my projects with old versions?
Thank you very much in advance.
- adickalvidi
