QUESTION/HELP
QUESTION/HELP
Postby BobF » Wed Mar 28, 2018 8:49 pm
Hello gang,
Say if I wish to change several knobs (2 or more) at the same time, what would be the best method? Thanks in advance for any and all help!
Later then, BobF.....
BobF
Re: QUESTION/HELP
Postby Spogg » Thu Mar 29, 2018 8:31 am
Hi Bob
Do you mean change the setting or change the graphics?
Re: QUESTION/HELP
Postby adamszabo » Thu Mar 29, 2018 8:50 am
I think he means editing them at the same time? You need to right click and use the synchronize painter and sync them.
adamszabo
Re: QUESTION/HELP
Postby BobF » Thu Mar 29, 2018 1:17 pm
Thanks guys!
Sorry, yes change setting.
Adamszabo, do you have an example. I have never used that feature?
Later, BobF....
BobF
Re: QUESTION/HELP
Postby adamszabo » Thu Mar 29, 2018 3:00 pm
It explains everything in the manual very well! Check page 84 in the user guide
adamszabo
Re: QUESTION/HELP
Postby BobF » Thu Mar 29, 2018 8:41 pm
THANKS!
BobF
Re: QUESTION/HELP
Postby BobF » Fri Mar 30, 2018 12:10 am
Ok, there is misunderstanding, my bad. What I want is when you move one knob all the others follow. For an example, say I have 5 delays. When I move the delay time knob for number 1, I want 2,3,4, and 5 also to move the same amount.
Thanks again, BobF.....
BobF
Re: QUESTION/HELP
Postby RJHollins » Fri Mar 30, 2018 1:12 am
These might be called 'LINKED' knobs.
I've seen on forum, a 2 knob linked ... not seen 3+ ...
It'd be interesting to see a working example.
One example I tried to explore was linking several knobs to a 'Master' knob that would allow for 'relative' adjustments.
It got difficult when one of those knobs/faders hit a Min or Max before the others. How to retain the original value relationships. I was not able to resolve :|
Re: QUESTION/HELP
Postby adamszabo » Fri Mar 30, 2018 3:41 am
Maybe you mean something like this?
link.fsm
(120.37 KiB) Downloaded 1198 times
adamszabo
Re: QUESTION/HELP
Postby BobF » Fri Mar 30, 2018 9:07 pm
YES, this is Perfect. Thanks, Adam.....
Cheers, BobF.....
BobF
