How to make Flowstone send PC keyboard key-press commands?
Dear Sirs,
by default the Flowstone reacts to PC keybord key-press messages by means of standard prim "Is Key Pressed".
Is there the way to perform the opposite operation (like with MIDI Message prim) - to send (emulate) specific key-pressed messages out of Flowstone, in my case, to the DAW host?
My need is to emulate "Home" key pressure command to send out of Flowstone to activate/reset FL Studio mixer channel position.
I guess there might be neccessary to address to external API32 application?
Would very much appreciate someone to share ideas and possibly, the code examples.... Thanks in advance.
- keyjslider1
Re: How to make Flowstone send PC keyboard key-press command
This belongs to "General", as it is not at all about DSP
I never used it myself, so I don't have Ruby code for you, but what you need is from the Windows API
SendMessage (with the WM_KEYUP or WM_KEYDOWN message)
Windows Dev Center link
However, the function expects a handle to the window that will receive the message, which will require you to find out that handle. I'm a little lost on that topic, maybe somebody else can help with that?
Moderator comment: I've moved this to General. Now why didn't I spot that it was in the wrong sub-forum? Too old.
tulamide wrote:This belongs to "General", as it is not at all about DSP![]()
I never used it myself, so I don't have Ruby code for you, but what you need is from the Windows API...
Tulamide thank you, SendKey and SenMessage do not work out of Flowstone as a FLStudio plugin, but Postmessage works fine. For my purpose I used keybd_event command, I didn't need finding out the window handle because the target window was always on top when the desired code had to be applied. I used the following code to send "Home" key in order to reset the FL's mixer position^
require "Win32API"
g=Win32API.new("user32","keybd_event", ['i','i','p','i'])
g.call(36,0,0,0)
g.call(36,0,'KEYEVENTF_KEYUP',0)
- keyjslider1
