"Last" green primitive action - Ruby version. Possible?
Postby kortezzzz » Sun May 27, 2018 7:40 am
Heya,
Was wondering if Ruby can output the last coming parameter(s) of one or more inputs, just like the green "Last"version does. If it can, which parameters can be instantly processed and how? I believe Arrays, integers, floats, strings and red clips are no problem. But what about a full midi event (status, channel, data1, data2) ?
I mean let's say I have 2 midi inputs that each of them gets a random signal from 2 sources, one at the time. Can I instantly output each of them by using "Last" method?
Examples for all kind of situations (midi and non-midi) are welcome :)
kortezzzz
Re: "Last" green primitive action - Ruby version. Possible?
Postby KG_is_back » Sun May 27, 2018 12:21 pm
def event v
output v
This should do the job. You can add arbitrary many inputs and it will send the last one to the first output.
Postby Spogg » Sun May 27, 2018 2:46 pm
KG_is_back wrote:
def event v
output v
Oh dear. I thought I understood event handling. I thought the order was input (index), value and time.
So I would have put def event i,v
If you just put def event v does Ruby know you mean value and not input?
Postby KG_is_back » Sun May 27, 2018 3:30 pm
There are 4 separate versions of event method
event()
event(value)
event(input,value)
event(input,value,time)
the first two are a little obscure, because they are usable in only the simplest cases. The last one is redundant because you can always access current time-stamp via time method.
Postby tulamide » Sun May 27, 2018 5:13 pm
I say this without having checked it in a RubyEdit, but I'm pretty sure that's wrong.
You can't just have event(v), it MUST be event(i, v). From the user guide, chapter 8:
For more advanced data handling you can define an event method. This is a special method which FlowStone looks for whenever it receives data at an input. The event method can have up to 3 input parameters:
▪ i - references the input at which the data arrived
▪ v - value that arrived at the input
▪ t - time at which the data arrived (schematic time in seconds)
You can have 0,1,2 or all 3 input parameters but you must add them in the order. So for example, you can have no parameters or
you can have i on its own
or i and v
or i and v and t
but you can't have v on its own or i and t without v.
EDIT: KG, Ruby doesn't support method overloading
Postby kortezzzz » Sun May 27, 2018 5:39 pm
KG_is_back wrote:
def event v
output v
I'm sorry KG, but it doesn't work for me. Tried it with integers, strings and floats pramenters.
kortezzzz
Postby Spogg » Sun May 27, 2018 5:50 pm
This is from an exercise I set myself early in my learning process.
It might be shit but it does work!
Last changed float .fsm
(95.21 KiB) Downloaded 869 times
Postby tulamide » Sun May 27, 2018 6:00 pm
Am I being ignored? Why so neglecting? Just replace "v" with "i,v" in KGs example and it should work.
def event(i, v)
  output v
Postby kortezzzz » Sun May 27, 2018 8:02 pm
It works, tula :)
Sorry, but I missed the syntax at your first comment. When you wrote it clearly at the last, I understood. It may sound obvious to you, but people with no coding skills sometime miss the context until you clearly write the code :lol:
kortezzzz
