BACKWARDS / FORWARDS - CROPPING SEQUENCER
Postby Casper78oo » Sun May 19, 2024 11:47 pm
this 32 step sequencer ( ATTACHED) can be adjusted to range from 1 - 32 steps.
1-1 steps
1-2 steps
1-3 steps
1-4 steps
1-5 steps
1-6 steps
1-32 STEPS
and so on.......
essientialy CROPPING THE LENGTH FROM THE END
I want to make this a BACKWARDS & FORWARDS CROPPING SEQUENCER SO I CAN ALSO CROP THE SEQUENCE FROM THE START
THIS WOULD ALLOW ME TO SELECT SPECIFIC REGIONS OF THE SEQUENCE
BY REMOVING STEPS FROM THE START (((NOT JUST THE END))
1-32 steps
2-32 steps
3-32 steps
4-32 steps
30-32 STEPS
AND SO ON....
IN SIMPLE, I WANT TO BE ABLE TO CUT OFF PARTS OF THE SEQUENCE FROM THE START NOT JUST THE END
CURRENTLY THIS SEQUENCER ONLY ALLOWS ME TO CUT OFF PARTS OF THE SEQUENCE FROM THE END
I WANT TO MAKE THIS A BACKWARDS & FORWARDS CROPPING SEQUENCER!!!!!!!!!!!!!
( I CANNOT FIGURE OUT HOW TO DO THIS )
I AM LOOKING FOR HELP !!!!!!!!!!!
- CASPER
32 step seq.fsm
32 step sequencer
(545.43 KiB) Downloaded 1244 times
Casper78oo
Re: BACKWARDS / FORWARDS - CROPPING SEQUENCER
Postby tulamide » Mon May 20, 2024 7:59 am
Try double buffering the sources array:
Start by exposing another knob for start of sequence. Make both values, start and length dependend by checking the other each time, one is changed.
start (0-based) is changed:
maxlen = 31 - start
len = [len, maxlen].min
length (0-based) is changed:
maxstart = 31 - len
start = [start, maxstart].min
In Ruby, always make a copy from sources (to keep its defaults) and instead work on a buffer copy by using:
buffer = sources[start, len]
Postby Casper78oo » Mon May 20, 2024 11:37 pm
Tulamide - would you mind fixing the schematic I posted so I can see what you’re talking about. I can’t really figure it out. If you wouldn’t mind modifying my schematic and reposting it so I can take a look. - Casper
Casper78oo
Postby tulamide » Tue May 21, 2024 9:43 am
I'm so sorry, but I don't have the time for that. But maybe someone else will take on the task? <Looks around the community>
Postby Casper78oo » Mon May 27, 2024 1:13 am
tulamide - your advice did not help. just really confused me more...... so i tried more using my own starategies
i added "select start" knob
(this is used to select the location that sequence should start from)
it will change to select location properly (WORKS) marked with a horizontal blue line
BUT
it will not read that location in the sequence it will just continue to read from the start
i want it to read from the new "SELECTED START" location
so - if select start was set so that NOTE 5 was the "SELECTED START" - NOTE 5 is where the sequence would begin to play from and NOTE 5 would be the first note played
I CANNOT FIGURE THIS OUT - it just keeps reading from the begining (0) EVEN THOUGH IT HAS BEEN MOVED TO THE NEW "selected start" LOCATION
ANY HELP???
also
does anyone do paid help/assistance for Flowstone??
i am looking for someone i could pay $$ to help me with my problems when they arrise
person would be paid through E-transfer - EACH JOB
32 step seq - position moving but not reading postver.fsm
CURRENT VERSION (NOT WORKING)
(719.98 KiB) Downloaded 1253 times
Casper78oo
